Andrei Urucu
Noua mea jucarie | Mitsubishi L200
49 postări în acest subiect de discuţie despre Noua mea jucarie | Mitsubishi L200
Andrei Urucu
Esti haios @Adrian N.:laughing:
Lectura placuta:
Super Select is the brand name of a four-wheel drive system produced by Mitsubishi Motors, used worldwide except for North America, where it was initially known as Active-Trac. It was first introduced in 1991 with the then-new second generation of the Mitsubishi Pajero.[1]
The system offers a choice of four rear- or four-wheel driving modes, selected using a lever mounted alongside the gear shift, and can be changed while the vehicle is in motion.[2] In 2H mode the front axle is disconnected and the vehicle is rear-wheel drive. Reduced frictional losses in the drivetrain mean that fuel economyimproves while noise levels are reduced.[2] 4H is a part-time four-wheel drive mode using a viscous coupling unit (VCU) and center differential to direct drive to the front wheels when the rear axle loses traction, and is capable of handling a wide variety of road conditions and speeds.[3] 4HLc locks the center differential to provide extra traction for sandy, snowy or poorly surfaced roads in "high range" mode, while 4LLc, the "low range" mode, also offers a much lower gearing, providing the maximum amount of traction. Changing between 4HLc and 4LLc is only possible with the vehicle stationary.[3]
@Cristian Gutescu nu o sa facem nimic, daca ai citit stirea, si cred ca ai facut-o, nu pot face nimic atata timp cat UK este in uniune, ( urmatorii 2-3 ani max) dupa acest interval o sa le interzica la imatriculat( nu o sa mai poti imatricula masini cu volan deochiat , dar, in acelasi timp, nu pot sa dea o lege cu efect retroactiv ( nu am mai vazut asa ceva) Acum masinile se imatriculeaza si asa or sa ramana ..dupa nu mai putem sa le vindem sau sa mai imatriculam altele.
Sunt constient de aceste masuri, sunt intr-un fel normale si chiar le agreez! M-am sfatuit cu un avocat pe tema asta ! Dar pana atunci , eu am o jucarie  la jumatate de pret fata de piata europeana pe care o folosesc exclusiv la rulota si la iesiri de placere sau de carat diverse ( nu este o masina de zi cu zi )
Adrian N.
Ai dreptate, nu ma asteptam. Misto dar in definitiv e un diferential deschis, nu LSD.
CristianG
Te-ai gandit cumva ca ai putea schimba volanul pe stanga ?
Andrei Urucu
@Cristian Gutescu nu zic NU! Dar nu am un plan pentru asta, dar daca imi pica una facuta praf pentru donarea pieselor necesare ..poate o iau in calcul. Dar asa cum am zis, nu merg cu masina la munca sau la piata ..am saptamani cand nu o pornesc ..si cand plec cu ea ..nu ma grabeste nimeni ..doar plec la distractie.
Fiind destul de inalta, pot sa vad peste turisme cand depasesc, iar pentru tiruri si dube ..am statie :) Nu ma grabeste nimeni ..la 90km/h cu rulota in spate ..merg cu 8, 7-9, 4 % asa ca ...
@Adrian N. asa cum am mai zis ...nu este avion sau tanc ..dar este mai mult decat la celalalte surori din clasa sa. nayhi
Modificat de Andrei Urucu
Manolescu Paul
Sa va bucurati din plin de noua achizitie.Cat despre consum va spun ca daca esti satisfacut  , nu conteaza vorba aceea :daca numeri macaroanele din budinca nu mai mananci niciodata.Drumuri bune.:salut!:
în urmă cu 12 ore, Adrian N. a scris:
Daca ma crezi tampit zi mi in fata, stiu destule despre masinile de genu asta. Ia zi mi tu despre alea mai multe functii chestii strumfi sau zane maselute ce crezi tu ca are acolo?
 Ce vascocuplaj stii tu pe acolo..., La ventilator bos nu in transmisie, haha,
Este clar mai mult decat un suv, dar nu minuni de neinteles de catre noi muritorii de rand.
@Adrian N.
Te rog sa pastram discutia in parametrii "tehnici" si intr-un cadru mai calm. Multumesc.
Andrei Urucu
@Gabriel Schuster nu este problema, am rezolvant neintelegerea cu @Adrian N..Acum, el, trebuie sa dea o bere la prima intalnire si eu pe cea de-a doua :bere:
Manolescu Paul
Dragi  colegi, eu cred ca cei care-si permit masini  super puternice, sa le stapaneasca sanatosi  si fara necazuri , Consumul este problema  fiecarui posesor de auto cu potential maxim.:salut!:
Sa mai spun ceva: Daca mananc , , scoici , , pe malul Marii Negre sau Bulz la Cheia sau  la Diham , tot Rulotist sunt., Indiferent  de motorizare sau Camper .Consinder ca ne respectam , reciproc si suntem  egali, , atata timp cit ne respectam si ne intalnim cu drag.:salut!:
Manolescu Paul
:clapping:Eu cred ca nu conteaza motorizarea sau Camperul(rulota) din dotare , pentru mine .conteaza  :valoareea omului cu care socializez , si cred ca ne agreem indiferent de dotari.
Manolescu Paul
Sa vedeti , ce  frumos  stim noi Manolestii sa ne distram?:clapping:
Manolescu Paul
Hai , Hai , la drum.:clapping:Pe timp frumos, sau pe furtuna, noi strabatem :munti si vai pe ale tarii noastre ????sosele.Va pupam .Hai Craiova.:buna-seara:
Andrei Urucu
lkm
Cristian Baetu
@Andrei Urucu iti aduc aminte de legea impozitului pe capacitatea cilindrica !! Apropo de legi retroactive ! Am avut noroc ca m-a prins numai cu motor de 3000 pe un BMW Seria 5. Mi-a fost mila de multi prieteni care si-au luat Porsche , sau alte traznai cu motoare de 5000 sau mai mult, ca trebuiau sa dea impozitul la primarie anual, mai mult decat facea masina .....asa ca in Romania noastra ma astept la orice!!! Iti mai spun ceva.....de ce crezi ca au dat ei (guvernarea) drumul la inmatriculat orice rabla?? O sa bage acus un impozit pe cat de mult iti polueaza masina....si iar mi-e mila de cei cu euro 2-3 !!
@Alin Cogalniceanu sa o stapanesti sanatos !!!
In rest, multa bafta si sa vina caldura !
Modificat de Paliu
Andrei Urucu
@Paliu asta cu impozitarea sunt si eu sigur ca or sa rupa..mai ales in conditiile in care sunt praf la buget. Legat de ce zici tu, este tot o lege care s-a aplicat din momentul intrarii in viguare si cu efecte ulterioare ( si are alt statut- taxe si impozite) Legat de atelajul meu, fiind N1 nu-mi bat capul cu impozitul ( nu are cum sa ajunga la o masina N1 de 2, 5 egala cu un auto M1 de 2, 5)  Iar legile care ingradesc un drept au aplicabilitate cu incepere din ziua publicari in MO fara sa influenteze trecutul. Vezi taxa auto ( tot ce s-a imatriculat inaintea introducerii, a ramas asa ( nu ai fost obligat sa platesti retroactiv) este clar ca masina asta o sa moara la mine sau la fier vechi, dar nu pot sa-mi interzica dreptul de a o conduce retroactiv ( dupa ce tot iei au imatriculat-o )
Andrei Urucu
Suntem gata de aventura, dupa lupte seculare, ce durara 2 luni, cu politia,  rar-ul si financiarul , avem numere :OK::cu-rulota:
  • Upvote 6
Andrei Urucu
Prima cumpana adevarata ... nici tractorul nu a reusit sa ne traga.
Ovidiu Cica
Andrei !
Zici de 9 la suta consum cu rulota?La ce viteza?Dar singura?
Daca aveai ceva AT-uri sau MT-uri era alta situatia !
Mi se pare ca ai gume de strada?
Unde s-a comis fapta?Si cum ai iesit ?
Irina Ursache
Cu asemenea cauciucuri nici nu e de mirare :( ; plus ca daca vrei intr-adevar off road, mai trebuie si troliu pentru asemenea situatii.
Andrei Urucu
în urmă cu 6 ore, Ovidiu Cica a scris:
Andrei !
 9% a fost un vis frumos ( s-a intamplat doar pe autostrada cand le-am adus acasa ( combustibil de “afara” pe drumuri ca afara”) acum 11-12%
Cauciuri am ok .. cooper discovery A/T 3, dar capcana a fost prea mare ( nici pe jos nu puteai sa mergi ) Era atat de lipicios si de adanc incat dupa doua manevre s-a suspendat de toate rotile
 Minunatia este undeva pe malul Jiului si am izbutit sa ies dupa ce m-a ridicat tractorul pe tiranti si am umplut cu pietre sub axa din spate ..
Andrei Urucu
27 minute în urmă, Irina Ursache a scris:
@Irina Ursache la un troliu visez de ff mult timp .. dar inca nu-si justifica existenta. Eu folosesc masina pentru rulota, pescuit si iarna la ski . Si mai mult un troliu nu vine niciodata singur .. mai apar si alte cheltuieli cu suspensia fata , ceva scuturi , bara HD, o baterie mai potenta .. poate a-2a chiar si lista poate sa continue ..
Irina Ursache
@Andrei Urucu si noi folosim masina pentru exact aceleasi scopuri. Noi am avut noroc ca am cumparat.o cu toate sf.urile deja puse pe ea, dar troliul l.am schimbat ca celalalt era tot ruginit si chiar am fost in situatii in care a trebuit sa ne folosim de el...oricum, ai reusit sa scoti printesele din glod? :)
Irina Ursache
Scuze, abia acum am citi mesajul de mai sus si observ ca ai reusit sa o scoti.
Anunt !
S-a deschis oficial platforma de vanzare accesorii Rulote si Autorulote www.xgocamping.ro, iar pentru membrii acestui forum oferim un discount de 5% de la preturile de pe site. Pentru comenzi mai mari, discountul poate fi chiar mai mare.
Pentru validare, transmiteti user-name de inregistrare pe xgocamping.ro si adresa de mail la contact@xgoautorulote.ro
Va multumim !
